Cadence in cycling is defined as the number of revolutions per minute (RPM) you complete at a given speed. The power you are able to produce on the bike is the product of torque (force on the pedal) x angular velocity (or your pedal speed). Based on this formula it is easy to see why an increase or decrease in your cycling cadence will directly impact the power you produce on the bike. While many cyclists will work towards their sought-after goal of increasing their threshold power, potentially a new benchmark could be to increase their cycling efficiency by focusing on cadence work.
Running and swimming are sports where poor form and efficiency will show themselves quickly by producing slower results. Cycling on the other hand is more forgiving and can allow people to ride relatively well even with poor pedaling form. When you watch elite cyclists, their ability to produce smooth cyclical motions seems effortless and much of this is attributed to their neuromuscular coordination that has been developed over years in the saddle, as well as attention to detail in improving cadence.
By increasing your cycling cadence at a given power, would then produce less force on your pedal, thus less muscular strain. While you reduce your muscular strain, this would in turn increase your time to fatigue. Riding at 130% of your FTP at 30-40 RPM most people would find it difficult if not impossible to maintain this for lengths of time over 90 seconds (some people may not even hit that!) On the flip side, if you tried to pedal at the same percentage but at 130-140 RPM, most riders would also struggle to make it beyond a minute or two due to the high cardiovascular strain this effort would take. ¿Por qué? This occurs due to decreased efficiency at higher cadences. In fact, most cyclists are only about 23% efficient in translating the energy placed into pedaling to power. How can you increase this? Practice, practice, practice!
Sign Up for Wahooligan Content Newsletter
Neuromuscular Coordination and Co-contraction
In order for the smooth, fluid movement to be produced requires complete synchronization of many different systems to communicate harmoniously with one another. You can think of it as an orchestra where many different instruments play simultaneously to produce a cohesive piece of music. This does not happen by luck, but by neuromuscular coordination. At first, the sound is a bit clumsy and incohesive, but over time and through practice it becomes one succinct sound. When your body performs high cadence work, your body communicates contraction and relaxation of the muscles involved out of sync and rhythm. This increase in neuromuscular communication is due to co-contraction. Co-contraction involves the two sets of muscles that surround a joint, flexors and extensors, and their simultaneous activation (trying to shorten.) An example of co-contraction would be flexing your bicep (elbow flexor) and tricep (elbow extensor) at the same time. Both muscles are contracting, but the lower arm is not moving.
We can relate this to a cycling pedal stroke. When pedaling a complete revolution, your muscles are not working independently. Leg muscles including the quads (vastus lateralis and medialis, rectus femoris), and hamstrings (biceps femoris (long and short head), semitendinosus, and semimembranosus) are all working together to produce smooth movement. If they worked independently, your motion would be very stiff and jerky. As the quadriceps lengthen and produce force into the pedals, your hamstrings shorten and produce a pulling movement against this force.
Why Does This Matter?
If you can improve your neuromuscular coordination on the bike, then you can ride harder….for longer. Incorporating cadence builds, cadence drills, and high cadence holds frequently in training can and will improve your neuromuscular coordination. This increase in coordination will improve your power across all ranges, not just the top end. No one ever rode faster by riding less efficiently.
Sessions to Improve Cycling Cadence:
Looking to incorporate some cadence drills into your own training? Try some of the following below:
60-minute ride including:
4-5 x 20-30 sec. cadence builds, 5-7 min. recovery
*Focus on engaging your core and be sure you are not bouncing out of the bike saddle.
60-minute ride including 3 sets of:
30 second cadence builds; recovery 1 minute
45 second cadence hold at 100% FTP (at highest cadence you can hold); recovery 1 minute
60 second single leg
60 second recovery
7 minute recovery between rounds
60 minute ride including:
3 x 20 second cadence builds
3 minute recovery between each effort
5 x 60 second 110-130rpm cadence hold at tempo effort
4-5 minute recovery between efforts
By regularly working on your cycling cadence, you’ll become a more efficient, faster, stronger rider. You’ll fatigue less and be able to go longer and harder.
27 July 2016
Thanks for the clearly stated info on cadence. Simple and easy to implement. This topic is not talked about as much as is needed. I never knew or read it helps endurance. Thanks!
9 November 2016
[…] course for your next key race. The applied resistance allows you to easily do intervals like low cadence strength work, which is difficult to achieve on a fluid trainer. Finally, using a smart trainer […]
8 March 2017
[…] some unexpected lessons quickly learned. For some reason, I wasn’t bringing my new found higher cadence with me on the road. I found myself falling back into old gear mashing habits. I used to […]
27 September 2017
Thanks will try this out later.
6 November 2017
[…] former world champion Michal Kwiatkowski, on an indoor KICKR session to increase your power using cadence drills. After a 5 minute steady warmup, Matt and the Team Sky riders perform four blocks of cadence […]
9 April 2019
[…] into training. Simply shift into a hard gear on your bike and pedal for 45-90 seconds at a cadence 25-35 RPM’s lower than your normal cadence range. This type of session is perfect for providing […]
23 July 2019
I really enjoyed this write up. Thanks.
29 February 2020
90 RPM is the cadence most professional athletes aim for. Try “Bike Beats” on Spotify for cadence training music!
https://open.spotify.com/artist/1VSMM1DM9r4cLTwaAYw4XI?si=4CFLRB93Rxa_bxnFSwWlXw
28 July 2020
wonderful, concise info to help me get my riding IQ up and break past my plateau 👍
3 January 2021
[…] where you’ll transfer all the power from your legs to the pedals to move the bike, typically at a rate of around 80 to 90 rpm. You’ll probably be turning the pedals about 4000 to 5000 times for every hour of […]
20 January 2021
[…] are more taxing on your muscle and burn through your glycogen stores. Tons of articles, such as this one, tell you to spin faster instead of […]
11 April 2021
[…] me; and the rest of the time I rode on the small ring. I did, however, maintain a pretty high cadence: average 81 rpm for the entire […]
4 July 2021
[…] Wahoo has a few more drill ideas here. […]
12 July 2021
[…] here is the cadence sensor. The pod (the bit at the bottom) goes in the mount (the bigger thing in the middle) and you […]
13 September 2021
[…] https://blog.wahoofitness.com/cycling-cadence-what-is-it-how-to-improve-yours/ […]
