ELEMNT RIVAL
RUNNING WATCH
ELEMNT RIVAL creates a seamless training and racing experience for runners. Powered by proven ELEMNT technology to provide a simple user experience to set up and customize the device to fit your lifestyle. With optical heart rate, barometric altimeter, ceramic bezel and water resistance up to 50m, ELEMNT RIVAL is your next GPS watch for running.
COMPRAR AHORAJim Walmsley - Western States 100 Champion
NUNCA PIERDAS DE VISTA TU OBJETIVO
ELEMNT RIVAL uses the intuitive ELEMNT OS to make the setup, customization and user experience of this GPS sport watch simple and seamless. Featuring a durable ceramic bezel, RIVAL boasts accurate GPS to track and record your runs, whether on the track, road or trails.
FÁCIL SEGUIMIENTO
With powerful and intelligent running features, ELEMNT RIVAL tracks time and workout data with minimal interaction between you and your watch, letting you concentrate on the task at hand – your training and race-day performance.
COMPRAR AHORA
FRECUENCIA CARDÍACA ÓPTICA
Check your heart rate and calorie data at a glance with ELEMNT RIVAL's built in optical heart rate. Set your zones in the ELEMNT Companion App to keep a pulse on your efforts.
ENTRENAMIENTOS PLANIFICADOS
Sync your TrainingPeaks calendar or choose one of our pre-loaded Wahoo Sports Science workouts to execute on RIVAL. As you run, interval prompts and target tracking are built into your sessions to keep you on pace.
PERFIL DE RUNNING EN PISTA
Use RIVAL's tracking running feature to snap to the nearest 100m distance on any standard 400m track to ensure your workout data is as accurate as possible.
TEMPORIZADOR DE TRABAJO-DESCANSO
Build out the intervals to fit your training. Create set periods for work and rest time and get prompted notifications during your workout to stay on track.
Fácil de ver
Gracias a su pantalla a color grande que utiliza un sensor de luz ambiental y Perfect View Zoom™, ELEMNT RIVAL funciona en cualquier condición de iluminación para que dispongas de los datos fundamentales de tu entrenamiento de un vistazo.
COMPRAR AHORA
SENSOR DE LUZ AMBIENTE
El sensor de luz ambiental de ELEMNT RIVAL mantiene tus datos de entrenamiento a la vista incluso cuando las condiciones no son ideales.
CÉNTRATE EN
TUS OBJETIVOS
Con Perfect View Zoom™, el reloj inteligente ELEMNT RIVAL le permite ampliar y reducir datos específicos del entrenamiento para que pueda ver fácilmente las métricas más importantes.
MUY CLARO
ELEMNT RIVAL está fabricado con Gorilla Glass, una pantalla altamente fiable y resistente a impactos que garantiza que tu reloj sea tan duro como tu rutina de entrenamiento.
OPCIONES DE COLORES
La resolución 240x240 de ELEMNT RIVAL ofrece datos de rendimiento en una pantalla LCD de 64 colores personalizable y fácil de ver, ya sea en la piscina o en la carrera.
Fácil de usar
With the most intuitive user interface, ELEMNT devices have dramatically changed the way athletes interact with their devices. ELEMNT RIVAL is optimized to give runners a focused advantage.
COMPRAR AHORALA EXPERIENCIA ELEMNT
La aplicación gratuita para ELEMNT cuenta con una interfaz para smartphone fácil de usar, que te guía a lo largo de la configuración, la creación de perfiles de entrenamiento, la personalización de pantallas de entrenamiento y la vinculación de tu ELEMNT RIVAL con tus aplicaciones de fitness y sensores inalámbricos favoritos.
NOTIFICACIONES INTELIGENTES
Con ELEMNT RIVAL puedes localizar fácilmente a otros amigos que estén entrenando en tiempo real. Además, la posibilidad de recibir correos electrónicos, mensajes de texto y alertas telefónicas te permite mantenerte siempre en contacto, incluso cuando no estés disponible.
MÁXIMA CONECTIVIDAD
Tanto si estás pedaleando, corriendo, nadando o simplemente entrenando, ELEMNT RIVAL se puede vincular con las aplicaciones de fitness y los sensores inalámbricos más populares para lograr una experiencia de entrenamiento completa.
SINCRONIZACIÓN INALÁMBRICA
ELEMNT RIVAL ofrece una experiencia realmente sencilla que te permite decirle adiós al lío de cables de conexión para sincronizar los datos de entrenamiento con tu portátil o actualizar el software de tu reloj.
TUTORIALES EN LA APLICACIÓN
Conocer el ELEMNT RIVAL es fácil gracias a un conjunto de tutoriales paso a paso. Las sencillas instrucciones te guiarán por las características exclusivas del RIVAL para garantizar que le saques el máximo partido a tu reloj.
EDITOR DE ENTRENAMIENTOS
Use Workout Editor on the ELEMNT Companion App to correct your segment timing on the Track Running or Triathlon profiles for variations between your watch and the official race results.
CONTROL KICKR
ELEMNT RIVAL te permite realizar tu entrenamiento de bicicleta en interiores. Al conectarse a los rodillos inteligentes KICKR de Wahoo, te ofrece un control total, en el que confía el medallista de oro olímpico y el triple campeón mundial del IRONMAN, Jan Frodeno.
ESPECIFICACIONES
ESPECIFICACIONES | |
Dimensiones | 46,5 x 46,5 x 15,3 mm |
Tamaño de la pantalla | Diámetro: 1,2” (30,4 mm) |
Tipo de pantalla | Color |
Resolución de la pantalla | 240 x 240 |
Material de la lente | Gorilla® Glass |
Material del bisel | Cerámica |
Material de la carcasa | Polímero de nailon |
Material de la correa | Silicona |
Longitud de la cinta | 10” (25,4 cm) Se ajusta a la circunferencia de la muñeca 140 mm - 240 mm |
Peso | 53 g |
Batería | Recargable de ion-litio |
Vida útil de la batería | Modo smartwatch: 14 días Modo GPS o FC: Hasta 24 horas |
Funciones GPS | Integrada |
Satélites compatibles | GPS y GLONASS |
Resistencia al agua | 5 ATM (sumergible hasta 50 metros) |
Botones zoom Perfect View | Sí |
Sensor de luz ambiente | Sí |
CONECTIVIDAD | |
Conectividad inalámbrica | ANT+® y BLUETOOTH® |
Compatibilidad con sensores | ANT+®, BLUETOOTH® y ANT+ FE-C |
Compatibilidad con teléfonos | iPhone y Android |
SENSORES | |
Altímetro | Sí |
Brújula | Sí, basado en GPS |
Giroscopio | No |
Acelerómetro | Sí |
Termómetro | No |
CARACTERÍSTICAS DE RELOJ | |
Hora/Fecha | Sí |
Sincronización de la hora por GPS | A través de la aplicación asociada ELEMNT |
Horario de verano automático | A través de la aplicación asociada ELEMNT |
Temporizador | Sí |
Cronómetro | Sí |
FUNCIONES INTELIGENTES | |
Configuración de la aplicación complementaria | Sí |
Pantalla personalizable | Sí |
Notificaciones | Llamadas, mensajes de texto, correo electrónico, WhatsApp, Signal, Line, Telegram y WeChat |
Seguimiento en directo | A través de la aplicación asociada ELEMNT |
Controle la música de su smartphone | Sí (solo iOS) |
Cargas automática de entrenamientos | Sí |
FUNCIONES DE SEGUIMIENTO DE LA ACTIVIDAD | |
Contador de pasos | Sí |
Calorías quemadas | Sí, calorías activas |
Pisos subidos | No |
Distancia recorrida | Sí |
Minutos de intensidad | No |
Tiempo de entrenamiento | Sí |
Distancia semanal de natación / bicicleta / carrera | Sí |
Perfiles de actividad | Ciclismo en interiores (KICKR), ciclismo al aire libre, correr al aire libre, cinta de correr, correr en pista, natación (piscina), agua abierta, entrenamiento de fuerza, yoga |
CARACTERÍSTICAS DE ANÁLISIS DEL ENTRENAMIENTO | |
Zonas de FC | Sí |
Calorías de FC | Sí |
Métricas de transmisión ANT+ y Bluetooth | Frecuencia cardíaca, ritmo de carrera y cadencia |
Velocidad y distancia GPS | Sí |
Páginas de datos personalizables | Sí |
Perfiles de actividad personalizables | Sí |
Autopausa | Sí |
Autocuentas | Sí |
Vuelta manual | Sí |
Mensajes de audio | Sí |
Hora de finalización | Sí |
Actividades multideporte automáticas | Sí |
Actividades multideporte manuales | Sí |
Bloqueo de los botones | Sí |
Historial de la actividad en el reloj | Sí |
INTEGRACIONES | |
Aplicaciones de actividades | Strava, TrainingPeaks |
Rodillos para interiores | Rodillos inteligentes Wahoo y rodillos equipados con ANT+ FE-C |
RECURSOS DE ELEMNT RIVAL
Echa un vistazo a estos recursos para aprender a sacar el máximo partido a tu ELEMNT RIVAL y a tu experiencia de entrenamiento.
What does proper running form look like? That depends on the individual, but there are principals to understand and aim for to ensure proper individual form. Learn what that means and how to apply it to your own training.
Do These Drills, Run Faster
How do you run faster? You may think, run more...but that is not always the answer and often leads to increased injury incident. Check out tips from our experts as to how to get faster in a safe and strategic way.
Ask the Experts: Tips for Running Through Tough Terrain
Branching out to more technical terrain often involves climbing, descending, and managing your footing, and is a much different experience than the path runs you’ve been knocking out. Learn more about how the type of terrain plays into your training, your level of fitness, and overall approach.
MY REASON | #MyRIVAL
Todos tenemos un rival que nos motiva a esforzarnos al máximo. Averigua en quién se fijan los atletas de Wahoo.
COMPARTE TU RIVALHAZTE WAHOOLIGAN
Etiquete #MyRIVAL o @wahoofitnessofficial para tener la oportunidad de aparecer en nuestras redes sociales. Se aplican términos y condiciones.
